3D Design
3D Design
conversion of solid into surface during using merge of surfaces tool ?
    • maurya
      hello Peter sir
                               during merge faces  tool,  solid body is converting into surface body.
      i am attaching video it will clear you the problem.
      at 1:26 solid body converted into surface
      thanks
    • peteroznewman
      Hello Deepak,
      If you zoom in, is it possible that a tiny sliver face was left unselected?  I found the selection tool could miss a small face.
      Show me what is on your Facets tab.  Do you have Skin Surface?  That may be more robust at covering the geometry with simple faces.
    • maurya
      hello sir
                     sorry i forget to attached the model.
      below is the image of facet tab
      yes skin surface is available in insert tool but it works only for .stl file, i think merging face may be simpler after this i will try skin surface.
      thank you
    • maurya
      hello sir
                 this is new video with zoom so that it confirm that no triangle should left.
      still problem is there
      thank you
    • peteroznewman
      Zoom in more, especially on the bottom edge.
      I see in Facets, they have Shrinkwrap. That could be good. I don't have that l license. But you say you have to start with STL faces...
Viewing 4 reply threads
