November 15, 2020 at 12:56 pm
JacobP
SubscriberHi there,nI have created a .cse file from a previous CFD-post processing I conducted. I was wondering whether it's possible to convert this into a .jou file to submit to a HPC for future batch jobs?nThanks so much for your help!nn -
November 16, 2020 at 7:34 am
DrAmine
Ansys EmployeeYou can launch CFD-Post in batch and use that session file to teach Post to use a cst file and do whatever you want to.nncfdpost -batch .cse .resn -
November 16, 2020 at 11:17 am
JacobP
SubscriberYou can launch CFD-Post in batch and use that session file to teach Post to use a cst file and do whatever you want to.cfdpost -batch
Thanks so much for your reply. nI am a little unclear on the process still - this is quite new to me. nMy current procedure on solving a .cas on the remote High Performance Computers in the first place is to write a .jou file and upload a related .sh file to the same location, then run the command below.nqsub Filename.shnWould your suggested method work to post-process the previously submitted case (that has solved)?n.cse https://forum.ansys.com/discussion/comment/97412#Comment_97412.res -
November 16, 2020 at 11:50 am
DrAmine
Ansys EmployeeEither you do the post-processing inside Fluent and there you need to start with at least -gu .driver null or to post-processing separately on the cluster using CFD-Post or EnSight. I am not sure if your cluster management allows you to do interactive things. For that reason you always can use batch post-processing with CFD-Post.n -
November 16, 2020 at 12:23 pm
JacobP
SubscriberEither you do the post-processing inside Fluent and there you need to start with at least -gu .driver null or to post-processing separately on the cluster using CFD-Post or EnSight. I am not sure if your cluster management allows you to do interactive things. For that reason you always can use batch post-processing with CFD-Post.https://forum.ansys.com/discussion/comment/97447#Comment_97447
My cluster does allow me to connect with an interactive GUI. But, I am most interested in batch post-processing via CFD-post. My aim is to produce a .wmv file from the velocity contours of my solve at each time step, with the time value labelled.nIs there any documentation or tutorials you'd recommend to read up on this?nThanks so much for your help @DrAmine, !n -
November 16, 2020 at 12:53 pm
DrAmine
Ansys EmployeePlease read the CFD-Post documentation. If you are just interested in having animation, better to tell Fluent to export high quality pictures and create animations after the run finished using ffmpeg or Ansys EnVe.n
- The topic ‘Converting .cse file into a .jou file for batch post-processing’ is closed to new replies.
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Difference between “total pressure” and “absolute pressure”?
- Drop Test of a Water-Filled Tube
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
