April 16, 2023 at 8:58 am
Chengkun Hu
SubscriberI would like to inquire about the professional methods for converting an antenna model designed in HFSS into a Gerber file. Currently, the known method involves converting each layer file into a DXF format, labeling the layers in AutoCAD, exporting them to a DWG file, and then converting them using software such as Altium Designer or Cadence. Another method is to import the model into HFSS 3D Layout for conversion. However, I am seeking more efficient and reliable techniques for this process. Any insights or recommendations from experienced users in the forum would be greatly appreciated. Thank you in advance for your help
May 10, 2023 at 2:33 pm
Aymen
Ansys EmployeeThe easiest available way now is to import the model into HFSS 3D Layout and from there exporting it in Gerber format.
- Maxwell, HFSS or Q3D?
- Error
5162
3275
2453
