Cooling load input hvac system simulation
    • jeefjef
      i am doing hvac simulation system with cooling load of home appliances with fluent, how do i input the cooling load of each equipment?nThanksn
    • DrAmine
      I understand it as you have a device which sucks air out of the room and serves as heat removal right?n
    • DrAmine
      Or do you want to calculate the cooling load like in : https://theengineeringmindset.com/cooling-load-calculation-cold-room/ I guess it is then a matter of heat fluxes and temperature evaluation of humid air HVAC system.n
    • jeefjef
      Scehmatic like this picturenI have appliances heat gain nTv 50wattnStove 900wattnHuman 50wattnWhere i can input the heat gain in ansys fluent?.n
      I'd include the solid bodies (person) and use a source term, possible a boundary heat flux (stove) and radiator (TV - it's too thin to want to use a solid, I would for an older style CRT). I like the representation of the people: shows you've realised that trying to capture all the detail isn't necessary in this type of model. Don't forget to include a heat loss mechanism or it'll get very warm in there.
    • jeefjef
      Thank you, i would try change the modeln
    • Mitesh Patel
      When designing an HVAC system, it's important to accurately determine the cooling load of the building to ensure that the system is appropriately sized and will operate efficiently.
      I suggested you to use EDS.Tech for cooling load. I also used this and it will be beneficial
      Thanx
Viewing 6 reply threads
