Coordinate System into center of gravity
    • Johnson
      Hi all,
      How can I put a coordinate system in the center of gravity in my model?
      Thanks
      Johnson
    • jj77
      Go to Coordinate Systems and right click and choose insert coordinate system.
      Choose to type in the global coordinates (see below) of the CG a shown below. If you do not know them (CG coordinates) then one way to find them, is by adding all parts in a multi body part and that will then give that info (CG of whole assembly of parts in the multi body part).
      This link/post shows how to do that (get CG): https://forum.ansys.com/forums/topic/how-to-find-center-of-gravity-and-moment-of-inertia/
    • Johnson
      Thank you very much!
