3D Design
3D Design
coordinate system
    • cini
      Dear all,
      I've designed a non constant section beam and I've turned it on 30° around Z, doing it in this way the beam dimensions on the bounding box are completely changed. I need to keep the same dimensions when the beam is rotate so, my question is, how can I do to keep the same dimensions on the two phases?
      Greatings,
      Cini
    • peteroznewman
      Please insert images to show what you have.
    • cini
    • peteroznewman
      Ignore the Bounding Box information. It is unimportant. It has nothing to do with your geometry or your model results.
Viewing 3 reply threads
