July 31, 2019 at 7:41 am
FrankR
SubscriberDear Community,
writing a profile provides the local distribution of a selected output quantity over the area of the selected surface. The coordinates of that surface are written by default.
So what is output if I select "x-coordinate", "y-coordinate" and "z-coordinate" from the list of output parameters ? These coordinates differ from the default ones.
Does this have anything to do with node locations and cell center locations ?
Your kind assistance is greatly appreciated.
Thank you & Regards
FrankR
July 31, 2019 at 9:39 am
Ansys EmployeeProfile should pick up the facet centre (when written), and use that along with the value you've specified or calculated. Note, if you manually write a profile that doesn't tie up with the mesh you use (ie you write a "square" profile and mesh with tri cells) Fluent will interpolate the input data.
Did you write the profile or a parameter?
July 31, 2019 at 2:12 pm
FrankR
Hello rwoolhou
thanks for your time. I define an object "quelle" in Fluent. It is of approximately rectangular shape, the top face is flat and at z = 1.045 m.
I obtain the data attached below when requesting "x-coordinate", "y-coordinate" and "z-coordinate" . Are these to be interpreted as the center points of the cells that have one face in common with the top face of "quelle" ?
Thank you once more & kind regards
FrankR
((quelle point 14)
(x
1.1833338
0.93350226
1.2666668
0.9333334
1.0168637
1.0166949
0.93336153
1.2668356
1.016667
1.1835303
1.2666671
1.1833615
0.93333381
1.2666949
(y
1.782999
1.2170076
1.6496452
1.649794
1.3115374
1.5445181
1.4449455
1.2168703
1.7830526
1.3114001
1.8830856
1.544423
1.8831391
1.444713
(z
1.045
1.045
1.045
1.045
1.045
1.045
1.045
1.045
1.045
1.045
1.045
1.045
1.045
1.045
(x-coordinate
1.1900868
0.92855662
1.2666667
0.95288461
1.0180861
1.0154058
0.95290571
1.2387316
1.0269746
1.1762527
1.2705796
1.1847528
0.92994529
1.2472528
(y-coordinate
1.7798049
1.2188135
1.6496453
1.620213
1.3157703
1.5412561
1.4665766
1.2472525
1.7716049
1.3181498
1.8846772
1.5328778
1.8791155
1.4580953
(z-coordinate
1.0730462
1.0913862
1.0913745
1.0710349
1.0730377
1.0710349
1.0710349
1.0821418
1.0867357
1.0821418
1.0906723
1.0856481
1.0912904
1.0856481
July 31, 2019 at 2:57 pm
Ansys EmployeePossibly: the input is the facet centre and it looks like your out values could be cell centre. If you use an inflated mesh from that surface what do you get?
July 31, 2019 at 3:09 pm
FrankR
SubscriberYou expect too much from me. I accept that my conjecture is at least approximately correct. With 2 months to go before the end of my contract I have little time to dig any deeper in this aspect.
Thanks
FrankR
2524
2066
1279
1096
457
