February 13, 2018 at 2:41 am
Hassaan
SubscriberI wanted to know how we can change the orientation of the axes in ansys (either in modal or design modeler or spaceclaim). I have to enter the value of forces in a direction which requires the orientation of axes. I need to orient my axes parallel to one of my parts. I would be very thankful to you for your responses.
February 13, 2018 at 3:57 am
February 13, 2018 at 2:10 pm
Hassaan
SubscriberThanks
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2716
2146
1357
1150
462
