August 1, 2019 at 8:02 pm
kjohnson10
SubscriberHello,
For some objects that are cut in HFSS, simply changing the coordinate system of an underlying planar geometry can result in perfect overlapping of parts.
However, when trying to overlap a helical design, the helix is offset.
This is not an urgent issue, but I do wonder what can be done to fix this without adjusting the the part in space.
Thank you in advance for any contributions.
-Kerry
August 1, 2019 at 8:04 pm
kjohnson10
SubscriberWait,
I figured out that you need to click the Global coordinate system before selecting the object to be copy/pasted.
This causes perfect overlap.
I have solved this issue.
- Maxwell, HFSS or Q3D?
- Error
2522
2064
1279
1094
456
