November 18, 2019 at 3:57 pm
shazimy
SubscriberHello
Is there a command to copy the CFX*.res file in another folder and rename it at the end of the run, in CFX workbench.
I know there is -name in batch mode; however, it is not working when using the workbench, adding it in "Solver Arguments".
Thanks,
Shahab
November 18, 2019 at 4:09 pm
DrAmine
Ansys EmployeeI would rather create a system script. -
November 18, 2019 at 5:26 pm
shazimy
SubscriberHello Amine,
Thanks for the reply.
I can search around and write system script. Meanwhile, I have access to CFX Customization course, so no issue in adopting pel.
My issue is that where to add this script so I can have it done at the end of each run, before results being deleted in optimization tools, if I don't want to retain all the points.
Kind Regards,
Shahab
November 18, 2019 at 5:29 pm
shazimy
SubscriberIn fact in Optimization,
I want to use the latest result as an Initial Condition for the nest run.
I tried different options in CFX solver workbench, the the initial is always the first run, not adding up.
Any suggestions? Or I am in the right track.
Shahab
November 19, 2019 at 6:14 am
DrAmine
Ansys EmployeeAre you retaining data of each dp? -
November 19, 2019 at 4:18 pm
shazimy
SubscriberYes,
Even with Retaining data, it starts with the dp0 *.res.
I am using R3.
November 19, 2019 at 4:21 pm
DrAmine
Ansys EmployeePaste the property settings of solution cell and DPs. -
November 19, 2019 at 4:43 pm
shazimy
SubscriberDear Amine
Do you mean pasting the property setting here? -
November 20, 2019 at 7:08 am
DrAmine
Ansys EmployeeScreenshots.
Anyway please have a look into "Specifying the Initialization Conditions for a Design Point Update" from the Help.
November 21, 2019 at 8:25 pm
shazimy
I read the manual carefully and tried all the options.
But still not initiating from cash solution or previous run for the next Dp.
It starts from CFX-pre set up initial or Current Dp( which is the first one).
Please look at the attached. I expected in this setup, the run starts from the last run but not.
Shahab
November 23, 2019 at 7:46 am
DrAmine
Ansys EmployeePlease check the part in the manual I was referring to. -
November 25, 2019 at 5:19 pm
shazimy
SubscriberHi Amine
Would you please address a little more specific?
I reviewed all of that but no luck.
Shahab -
November 25, 2019 at 5:22 pm
DrAmine
Ansys EmployeePlease have a look into "Specifying the Initialization Conditions for a Design Point Update" from the Help.
I cannot now paste any screenshots. You find the option under properties of dps -
November 25, 2019 at 6:12 pm
shazimy
This is the link that I went through and followed everything carefully.
I tried All options!
Shahab
November 25, 2019 at 6:39 pm
DrAmine
Ansys Employeehttps://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v195/wb2_help/wb2h_updatingdp.html?q=Specifying%20the%20Initialization%20Conditions%20for%20a%20Design%20Point%20Update
5454
3419
2473
1310
1022
