January 24, 2022 at 9:38 am
aabdelrahman88
SubscriberHello,
When calculating the stator core loss using both Ansys embedded formulas and field calculator, I found that there is a significant difference between both (please see the attached figure). Any idea where this difference might come from.
Red waveform: using field calculator (integrate(statorvolume.CoreLoss))
Green waveform: Create Transient Report - Rectangular Plot - Loss - CoreLoss(Stator)
Thanks for your help.
January 28, 2022 at 10:40 amNavya C
Ansys EmployeeHi @aabdelrahman88 When you are calculating the core loss using the field calculator you need to multiply it with the symmetry multiplier in the formula in the case of 3D and in the case of 2D you need to multiply with stack length also.
Please check that.
Regards Navya
January 28, 2022 at 1:18 pmaabdelrahman88
SubscriberThanks so much. Is it the same when calculating copper loss using field calculator Integrate(Volume(windings).OhmicLoss)? Should I multiply by stack length and symmetry multiplier too?
- Maxwell, HFSS or Q3D?
- Error
3744
2573
1821
1236
596
