February 18, 2021 at 1:37 pm
atulsingh92
SubscriberHi, nI wanted to know if there is IDE toolkit that I could download for correctly debugging UDF's within some IDE.nThe reason is, my current method seems long and inefficient, or perhaps I am unaware of a better one.nI usually write my udf's in a text editor, then build and load within fleunt (2019R2), then I run my simulation and execute on demand if any.nNow, if have to change something in the text editor and update again, I first unload from fluent, then add my new text (c) file, and then build and load again.nBetter way would be to have a zip files of all the necessary files imported to VS studio or vs code, or any other IDE, and write ready to run c files over there, and debug there itself, before importing to fluent.nCould you suggest anything on this?n -
February 18, 2021 at 5:12 pm
Ansys EmployeeYou can compile externally, using VS Studio or (possibly) CLANG that's in the newer releases of Fluent. If it's not in the manual however, you'll need to rely on the wider community for assistance. n
5364
3363
2471
1310
1018
