Corrosion in Ansys
    • karthikeyan506
      Hi, I like to simulate corrosion in Ansys for composite materials . Is there any add on available for it? or it there any codes in apl for them
    • PSiedlac123
      What effects of corrosion You would like to analyze? Mechanical weakening, Damage, Diffusion, Chemical or Electrochemical product forming ... I suppose most of these chemical /CFD problems can be solved with ANSYS Fluent, and mechanical part with ANSYS APDL.
      Here You can start with some reading:  https://support.ansys.com/staticassets/ANSYS/Conference/Houston/downloads/Numerical%20Simulation%20of%20Flow%20Induced%20Corrosion%20-%20SW%20Research.pdf
    • karthikeyan506
      Hi, I would like to do everything related to corrosion. DO you have anys simulations with you related to corrosion and can you possibly share with me.
      You need to be more specific, and figure out what you need (and can afford to do given time and software & hardware constraints) before trying to model anything. Ie are you worried about FeO, FeO3, FeS etc, is the oxide stable, does it alter the surface or risk "blowing" composite material.
    • karthikeyan506
      I am trying to do oxidation on composite materials. I just need to determine thermal stresses, analysis of interlaminar stress. Do you recommend any softwares. I have access to ANSYS. I need to verify the surface topography and corrosion on coated surfaces of composites. Do you have some files which you have studied.
Viewing 4 reply threads
