August 30, 2023 at 3:39 am
APOORVA S
Subscribercan i get procedure to induce corrosion in steel reinforcement in concrete exposed to marine environment?
August 30, 2023 at 10:10 am
Ashish Kumar
Forum ModeratorHi,
Please see if the following links work:
Corrosion Modeling in Ansys Fluent | Ansys Webinar
Ashish Kumar
September 25, 2023 at 8:32 am
sixog daioqp
SubscriberCertainly! Inducing corrosion in steel reinforcement in concrete exposed to a marine environment is typically not a desired outcome, as it can compromise the structural integrity of the concrete. However, if you are conducting research or testing related to corrosion resistance, it's essential to follow proper procedures with safety precautions in place.
Please remember that corrosion in concrete structures can lead to significant damage and safety hazards. If you're looking to study corrosion, it's essential to do so under controlled conditions and with proper safety measures. I recommend consulting with corrosion experts or materials testing laboratories for guidance on conducting such experiments safely and responsibly.
- Invalid Assignment error
- How do I make a chart with multiple material parameters on y-axis?
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- How to add SN curve for new material in Fatigue analysis?
- ANSYS 19.0 with Additive Manufacturing Extension
- properties of balsa wood
- Looking for Spring steel (55Si7) library material
- About Bilinear Isotropic Hardening Plastic Model !
7732
4484
2957
1449
1322
