December 13, 2022 at 11:19 am
December 13, 2022 at 6:32 pm
Guilin Sun
Ansys EmployeeSince there are several variables, it can be challenge to directly give a solution. What I can suggest is, online 35, please use
?kern; ?length(J);
I guess the length of J and V is less than kern, then kern+1 is out of the matrix range.
December 13, 2022 at 6:50 pm
December 13, 2022 at 7:07 pm
Guilin Sun
Ansys EmployeeSorry, you did not write those two:
?kern; ?length(J);
it will output the value of "kern" and the length of the J matrix.
If you use kern=length(J) then the next script will be definitely wrong, as you can not get J(kern+1) since its size is "kern".
Please try again.
December 13, 2022 at 7:23 pm
December 13, 2022 at 8:00 pm
Guilin Sun
Ansys EmployeePerhaps you are not familiar to scripting. The question mark is to output the data. You did not provide the data from the bottom of the script file, so no further suggestion is available. Maybe you can check if J has negative values. If not, then
kern=0 so J(kern) will fail.
On the other hand, you should not use kern=length(kern) since kern should be one value, scalar, not a matrix. Please delete line 34. and check the result.
Please note that line 37 is to cacualte the matrix difference. If the matrix fails, or the denominator is zero, line 37 will fail.
Please watch some script videos once this issue is solved. https://optics.ansys.com/hc/en-us/sections/360007813714-SCRIPTING100-List-of-videos
kern
December 13, 2022 at 8:10 pm
Iqrar Hussain
SubscriberSir Thank you for your guidance
I appreciate your effort.
- Error on Lumerical device
2582
2080
1303
1106
459
