September 29, 2018 at 2:01 am
September 29, 2018 at 2:03 am
LastFreeMason
SubscriberLicense on my personal computer given in connection with my university
October 1, 2018 at 4:33 pm
October 2, 2018 at 7:14 am
LastFreeMason
SubscriberHope this is what you need:
19:17:50 (lmgrd) Server's System Date and Time: Sat Sep 22 2018 19:17:50 Central Daylight Time
19:17:50 (lmgrd) pid 7876
19:17:50 (lmgrd) SLOG: Summary LOG statistics is enabled.
19:17:50 (lmgrd) Done rereading
19:17:50 (lmgrd) FlexNet Licensing (v11.13.1.3 build 176543 x64_n6) started on LAPTOP-G8J9BDG8 (IBM PC) (9/22/2018)
19:17:50 (lmgrd) Copyright (c) 1988-2015 Flexera Software LLC. All Rights Reserved.
19:17:50 (lmgrd) World Wide Web: http://www.flexerasoftware.com
19:17:50 (lmgrd) License file(s): C:Program FilesANSYS IncShared FilesLicensinglicense_filesansyslmd.lic
19:17:50 (lmgrd) lmgrd tcp-port 1055
19:17:50 (lmgrd) (@lmgrd-SLOG@) ===============================================
19:17:50 (lmgrd) (@lmgrd-SLOG@) === LMGRD ===
19:17:50 (lmgrd) (@lmgrd-SLOG@) Start-Date: Sat Sep 22 2018 19:17:50 Central Daylight Time
19:17:50 (lmgrd) (@lmgrd-SLOG@) PID: 7876
19:17:50 (lmgrd) (@lmgrd-SLOG@) LMGRD Version: v11.13.1.3 build 176543 x64_n6 ( build 176543 (ipv6))
19:17:50 (lmgrd) (@lmgrd-SLOG@) === Network Info ===
19:17:50 (lmgrd) (@lmgrd-SLOG@) Listening port: 1055
19:17:50 (lmgrd) (@lmgrd-SLOG@) === Startup Info ===
19:17:50 (lmgrd) (@lmgrd-SLOG@) Is LS run as a service: No
19:17:50 (lmgrd) (@lmgrd-SLOG@) Server Configuration: Single Server
19:17:50 (lmgrd) (@lmgrd-SLOG@) Command-line options used at LS startup: -c C:Program FilesANSYS IncShared FilesLicensinglicense_files -l C:Program FilesANSYS IncShared FilesLicensinglicense.log
19:17:50 (lmgrd) (@lmgrd-SLOG@) License file(s) used: C:Program FilesANSYS IncShared FilesLicensinglicense_filesansyslmd.lic
19:17:50 (lmgrd) SLOG: FNPLS-INTERNAL-VL1-4096
19:17:50 (lmgrd) Starting vendor daemons ...
19:17:50 (lmgrd) Started ansyslmd (pid 584)
19:17:50 (ansyslmd) SLOG: Summary LOG statistics is enabled.
19:17:50 (ansyslmd) SLOG: FNPLS-INTERNAL-CKPT1
19:17:51 (ansyslmd) SLOG: VM Status: 0
19:17:51 (ansyslmd) SLOG: FNPLS-INTERNAL-CKPT2
19:17:51 (ansyslmd) Warning: aa_mcad expires 24-sep-2018
19:17:51 (ansyslmd) Warning: aa_r expires 24-sep-2018
19:17:51 (ansyslmd) Warning: afsp_gui expires 24-sep-2018
19:17:51 (ansyslmd) Warning: afsp_optigrid expires 24-sep-2018
19:17:51 (ansyslmd) Warning: afsp_viewmerical expires 24-sep-2018
19:17:51 (ansyslmd) Warning: aim_mp1 expires 24-sep-2018
19:17:51 (ansyslmd) Server started on LAPTOP-G8J9BDG8 for:aa_mcad
19:17:51 (ansyslmd) aa_rafsp_guiafsp_optigrid
19:17:51 (ansyslmd) afsp_viewmerical aim_mp1
19:17:51 (ansyslmd) EXTERNAL FILTERS are OFF
19:17:51 (lmgrd) ansyslmd using TCP-port 49871
19:17:51 (ansyslmd) Serving features for the following vendor names:
ansyslmd ansoftd
October 2, 2018 at 4:04 pm
tsiriaks
Ansys EmployeeHi LastFreeMason,
If the licenses are hosted locally on your machine and if you are not sharing these licenses to anyone, you can try this workaround.
Make sure all ANSYS applications are closed.
Open up the ANSYS License Management Center > click Stop
Launch the Client ANSLIC_ADMIN Utility v1x.x with "run as administrator" > Specify the License Server Machine > Highlight the row in the box that you are specifying your hostname > Edit Server Machine Specification > in the Hostname 1 box , type localhost > OK
Then, modify the content of the installed license file (in your case, it is C:Program FilesANSYS IncShared FilesLicensinglicense_filesansyslmd.lic), so that the SERVER line (the first line) in the file is using 127.0.0.1 instead of your machine hostname, something like this
SERVER 127.0.0.1 ######### 1055
From ANSYS License Management Center > click Start
Does this help ?
Thank you,
Win
October 9, 2018 at 11:22 pm
LastFreeMason
SubscriberThat fix didn't work.
Here is what I changed the installed license file to:
What can I do now?
SERVER 127.0.0.1 DISK_SERIAL_NUM=e2c03cc9 1055
VENDOR ansyslmd
USE_SERVER
# Products licensed in this file:
# 1. ANSYS Academic Research Mechanical and CFD (5 tasks): 1 task(s) Evaluation expiring 24-Sep-2018 Customer # 1107215
INCREMENT aa_mcad ansyslmd 9999.9999 24-sep-2018 5 4928D0A156BA
VENDOR_STRING="eval customer:01107215" ISSUER=AUFI_EVAL
ISSUED=29-jun-2018 START=29-jun-2018 SIGN2="0084 1FFA A6E1
2F74 70E6 8EB5 E9EF 1000 86A0 CD56 B221 0753 1EBE 5BD2 C446"
INCREMENT aa_r ansyslmd 9999.9999 24-sep-2018 5 BE55CE000F03
ISSUED=29-jun-2018 START=29-jun-2018 SIGN2="004B 62F6 1A2F
2877 05D7 73E8 E82C 2000 C530 A1E4 DD6C 4881 9052 FB09 1A67"
INCREMENT afsp_gui ansyslmd 9999.9999 24-sep-2018 5 2F970A5B842C
ISSUED=29-jun-2018 START=29-jun-2018 SIGN2="0088 1363 313B
0F83 832F B6EB 12EC 7B00 C4D0 451F ECA2 12DE 04EF 71E3 242F"
INCREMENT afsp_optigrid ansyslmd 9999.9999 24-sep-2018 5 7B5372508784
ISSUED=29-jun-2018 START=29-jun-2018 SIGN2="0073 DE16 CBF0
4389 DC6F 9B2F D506 2100 74BA CF1B 7B71 59F8 1B9F 4E12 E316" -
October 9, 2018 at 11:23 pm
LastFreeMason
SubscriberAlso, I just noticed but does the "evaluation expiring 24-Sep-2018" mean that my license already expired?
October 10, 2018 at 12:18 am
tsiriaks
ah yea, that means the license already expired. Please reach out to your ANSYS Account Manager.
Thank you,
Win
- Workbench error
- Workbench not opening
- License Error
2688
2138
1349
1136
462
