August 14, 2018 at 8:41 am
ANKIT
SubscriberEvery time I try to start 'user licence preference 19.1' it shows 'Could not connect to licence server: 50448@localhost The handle is invalid'
I am using windows10 and installed Ansys19.1.
I have twice reinstall windows and also install previous version Ansys19.0 . None of it works.
Please help.
August 14, 2018 at 11:25 am
DrAmine
Ansys EmployeeAre you able to work or this is only hapening if you try to start user license preferences?
Can you please try renaming the Ansys folder under %appdata% to Old_Ansys and try again?
August 14, 2018 at 5:52 pm
tsiriaks
Ansys EmployeeHi ANKIT ,
You can also try this: Go to C:WindowsSystem32driversetc , then open up 'hosts' file and uncomment (remove the '#' in the front) the line 127.0.0.1 localhost
If that doesn't help, please change it back.
Thank you,
Win
August 14, 2018 at 8:53 pm
ANKIT
SubscriberI am not able to work.
August 14, 2018 at 8:54 pm
ANKIT
SubscriberI tried it by removing #, but it does not work.
August 14, 2018 at 11:27 pm
tsiriaks
Are you using the free student version or academic license version ?
Try temporarily disabling Firewall and anti-virus software on your machine to see if that helps. If it helps, you can turn it back on but make sure to add exceptions/exclusions to (default path)
Student version
C:Program FilesANSYS IncANSYS StudentShared FilesLicensingwinx64ansysli_client.exe
C:Program FilesANSYS IncANSYS StudentShared FilesLicensingwinx64ansysli_util.exe
Paid academic license version
C:Program FilesANSYS IncShared FilesLicensingwinx64ansysli_client.exe
C:Program FilesANSYS IncShared FilesLicensingwinx64ansysli_util.exe
Thank you,
Win
March 10, 2019 at 10:06 am
Sathvik
SubscriberHello!
i almost tried everything mentioned here in Ansys student community, Still not able to solve (Could not connect to licence server: 49679@localhost The handle is invalid) problem.
I earlier had installed Ansys student version 18.2, When it expired instead of renewing it i uninstalled and deleted all the files from my laptop. Now i downloaded the latest ansys student 19.2 and i receive the above highlighted message as i open the workbench.
I need to badly use Ansys fluent for my thesis. Kindly help me
with regards,
Sathvik
March 11, 2019 at 1:01 pm
JakeC
Ansys EmployeeHi Sathvik,
Are you using the Student version or are you using an academic license?
When you removed version 18.2, did you delete the entire c:program filesansys inc directory, or just the v182 directory?
Please try renaming the c:program filesansys incshared files directory to shared_files_old then reinstall 19.2
If that doesn't work, please try disabling the windows firewall and any antivirus software you may be running.
Lastly could you please open task manager and in the details tap sort by name and post a screenshot of items listed.
We are specifically looking for Ansysli_Monitor, Ansysli_Server, Ansyslmd, and lmgrd.
Thank you,
Jake
May 13, 2019 at 12:39 pm
AravindKarthik
SubscriberHI, I am facing the same issue. Tried lots and lots of solutions but not even a single solution seemed to work. I will send you screenshots of anything as per your requirement. Please rectify this issue for me. I need this problem to be solved badly sir. Please rectify this sir.
Thank you in anticipation
May 13, 2019 at 1:22 pm
JakeC
Ansys EmployeeHi AravindKarthik,
Please follow the instructions in my last post on this thread.
Thank you,
Jake
May 13, 2019 at 1:25 pm
AravindKarthik
SubscriberI tried the solution sir. That didn't seem to work for me..... Please suggest any alternative solution sir.
May 13, 2019 at 1:27 pm
JakeC
What did you see with the final instruction:
"Lastly could you please open task manager and in the details tap sort by name and post a screenshot of items listed.
We are specifically looking for Ansysli_client, Ansysli_Monitor, Ansysli_Server, Ansyslmd, and lmgrd."
Thank you,
Jake
May 13, 2019 at 1:44 pm
May 13, 2019 at 1:51 pm
JakeC
Ansys EmployeeAre you trying to use the Student version or the Academic version?
In the Windows search , type
%temp%.ansys
then look for the file that says 'demo.
.log'
Open this file up and scroll to the bottom of the file and send me the screenshots of it
Also, make sure that your username has only English letters (A to Z)
Thank you,
Jake
May 13, 2019 at 1:57 pm
May 13, 2019 at 2:02 pm
JakeC
Thank you for the screenshot.
I will need to ask around for that one. In the meantime it might be best to try reinstalling the application.
Please make sure that after you uninstall the old one, that you delete the c:program filesansys incansys student directory.
Thank you,
Jake
May 13, 2019 at 2:23 pm
AravindKarthik
SubscriberOkay sir. Will try uninstalling the file as per your instruction and update you regarding the status of the problem soon.
Thank you
May 13, 2019 at 5:17 pm
tsiriaks
Can you also try a username that doesn't have a space ? You can create a test user account and name it like abc , or xyz , or ansys , etc.
Also, can you create a new thread exclusively for your issue ?
Thanks,
Win
May 13, 2019 at 6:17 pm
May 13, 2019 at 6:30 pm
AravindKarthik
SubscriberHello tsiriaks,
Will try the recommended settings as you suggested sir and will update you regarding this back to you.
**edit**
Added a new discussion sir
May 14, 2019 at 12:07 am
tsiriaks
Ansys EmployeeThank you AravindKarthik.
I'm locking this post for now. If anyone else needs help, please create a new thread.
Thanks,
Win
- Workbench error
- Workbench not opening
- License Error
2688
2138
1351
1136
462
