February 21, 2022 at 2:20 pm
Muhammad_atif
SubscriberHi,
I have created a new case and created the geometry of a valve using Spaceclaim. It was working fine at that time and I Ran the analysis and closed the case. When I reopened the same workbench file, for some reason Spaceclaim is not loading. I have tried in a new workbench case and SpaceClaim is initially working but after closing and reopening the same file, the SpaceClaim is not loading again. when I use the same file on another computer, it works fine. I am using a research license.
I have attached a screenshot of what the project looks like after reopening.
Any help would be highly appreciated.
Thanks
February 22, 2022 at 4:04 amKeyur Kanade
Ansys EmployeeCan you please run CAD configuration manager once again and check if works.
You can also check following post.
Can't import Spaceclaim Geometry into Fluent ÔÇö Ansys Learning Forum
Please go through help manual for more details
Regards Keyur
February 23, 2022 at 9:07 amMuhammad_atif
SubscriberHi Thanks for your reply. I tried running CAD manager and checked spaceclaim option but no improvement!
February 24, 2022 at 3:51 amKeyur Kanade
Ansys EmployeePlease try reinstallation.
Trending discussions- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2726
2148
1359
1150
462
