March 25, 2021 at 12:31 am
nuwan
SubscriberHi experts,
I am using ANSYS 19.2. I want to impact two elements. And I want to add a point mass on moving element in the simulation. My simulation was OK without a point mass. But my simulation does not work with a point mass.
At the beginning it shows me an error "Deformable behavior for remote entities is not supported in Explicit Dynamics systems. Please change such behavior to Rigid". And I changed the behavior of the point mass to rigid. Now I got an error "Could not transfer loads and constraints to the solver".
March 25, 2021 at 1:00 pm1shan
Ansys Employee,nWhen you set the deformation behavior as rigid, all the surfaces that are scoped to the point mass become rigid in a sense. So if you have any boundary conditions/loads that are scoped to these surfaces (to which point mass is attached) it might create problems. Could ensure that this doesn't happen in your case. Also, provide an image of your boundary conditions, loads and surfaces to which remote point is scoped.nRegards,nIshan.nViewing 1 reply thread- You must be logged in to reply to this topic.
Trending discussions- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
2564
2080
1299
1106
459
