April 25, 2020 at 10:26 am
ArunMohan
Hi guys, i have attached the image which shows the error message as above. I used ANSYS STUDENT 2019R2 and it shown this error message for first time . So i thought that it's about version and i installed ANSYS STUDENT 2019R3 version but again same thing happens. And i got only below feature in workbench window.
April 26, 2020 at 2:53 am
April 27, 2020 at 10:42 am
Forum ModeratorStudent has it's own inbuilt licence manager and tends to conflict with any "normally licenced" Ansys products. Have you got another version installed?
April 27, 2020 at 4:44 pm
ArunMohan
Subscriberi had installed 2019R2 version which shown the error first time and at that time i had only one version . Important to note that is, it worked well and i simulated various models.And for a while I hadn't used certain period . when i revisited to Software i encountered this issue .
As i stated , i unistalled the R2 version and installed the 2019R3 version but facing same issue.
Thanks for your response.
- The topic ‘Couldn’t open ANSYS workbench’ is closed to new replies.
- acces to path ‘session_files’ is denied error
- Fluent and Rocky DEM coupling in Ansys student
- unexpected license problem; exiting. hit return to exit.
- Ansys Student 2025 R1 – Ansys Discovery did not install
- No FlexNet Publisher (FNP) license found for feature HPC Parallel.
- Ansys Electronics Desktop crashes when trying to set the steel type in RMXprt
- Workbench application not showing up after installing Ansys Student 2024 R2
2793
965
851
599
591
© 2025 Copyright ANSYS, Inc. All rights reserved.
