Ansys Products
Ansys Products
Couldn’t open the project file (Error Migrating dp0 Design Point from Handler)
    • Yaw Fang Yip
      Hi all, does anyone have encountered this error message before?
      I couldn't open my project file, and this error message pop out.
      Why does this error occur?
      Unable to load project 'C:\Users\YawFang\Desktop\t\BT07756-AS-100_00_3.wbpj': Ansys.Core.Persistence.Migration.MigrationException: Error migrating dp0 design point file from handler Ansys.Simulation.Core.Addin:AddSpeosObjInSolutionContainer ---> System.InvalidOperationException: SubObject already exists with the same name: Tag: Object Name: /Solution/SimulationSolutionSpeosObj:SimulationSolutionSpeosObj
         at Ansys.Core.Persistence.XmlStorageObject.CreateSubObject(String name, String subName)
         at Ansys.Core.DataModel.DataObjects.Persistence.DataObjectReaderWriterV1.WriteSimpleObjectFromType(Type objectType, String objectName, IStorageObjectWriter containerStorage)
         at Ansys.Simulation.Migration.AddSpeosObjMigrationHandler.Visit(IStorageObjectWriter storage, XmlStorageVisitorContext context)
         at Ansys.Core.Persistence.XmlStorageObject.Accept(IXmlStorageVisitor visitor, XmlStorageVisitorContext context)
         at Ansys.Core.Persistence.Migration.ProjectMigrationManager.ApplyMigrationHandler(MigrationHandlerBase handler)
         --- End of inner exception stack trace ---
         at Ansys.Core.Persistence.Migration.ProjectMigrationManager.Migrate(PersistenceContext context, Boolean isImportedProject, Boolean& migrationWasExecuted)
         at Ansys.Core.DataModel.ProjectSystem.Project.LoadProject(String projectFilePath, PersistenceContext context, Boolean merge, Boolean import)
         at Ansys.Core.Persistence.Commands.OpenCommand.LoadProjectInternal(IFullContext context, String projectFilePath, Boolean mergedProject, Boolean importProject, AccessLock shareLock, Boolean skipStartingEvents, IReadOnlyDictionary`2 addinsToPostMigrate)
    • Aniket
      It is possible that project is fully corrupted and not able to recover automatically. You can try to use the manual recovery step as mentioned in:
      How to restore the corrupted project in ANSYS Workbench? - Ansys Knowledge
      -Aniket
    • Raihan Lutfianto
      Hey, are there any solutions besides restoring the corrupted project? How can we prevent it in the future?
    • Raihan Lutfianto
      Thanks for the answer Aniket. I will keep you posted.
Viewing 3 reply threads
