Couple FSI with Ansys Maxwell
    • zaiat
      Hello dear Ansys community!
      I am currently considering switching to Ansys for my further research at my institute. I have already tried quite a bit in the student version and so far I am thrilled!
      But before I get a license, I would like to know if my goal is feasible in Ansys. Specifically, I would like to use an FSI as part of my research. These, a fluid is forced through a narrow gap, pushing the solids faces apart. From this deformation of the solids, the electric field strength or the electric capacity should be calculated.
      At first sight, however, I do not see any option to connect these two packages with each other. In Google I found only entries for either one or the other.
      I therefore ask you as experts in Ansys, whether I can implement a model consisting of FSI+Electrostatic or Maxwell within the framework of a research license? And if not, can I import the result from FSI e.g. into Maxwell instead?
      Thank you very much and have a nice weekend! :)
    • Navya C
      Hi@Zaiat,
      No,  you cannot link FSI(I assume it is from COMSOL)+Maxwell.
      But you can do the multiphysics simulation you are trying to do if you use Fluids and Maxwell.
      Navya
    • zaiat
      Hello Navya,
      thank you for your response!
      I actually dont want to link Ansys with Comsol, I just want to do everything in Ansys. An FSI is just the overarching term, in Ansys specifically its called System Coupling.
      So basically, in Ansys terms, I want to do a system coupling of Fluent+Structural, and then add Maxwell on top. I believe that should be possible as well...?
      Thank you
    • Navya C
      Hi Zaiat,
      Yes, that is possible.
      Navya
Viewing 3 reply threads
