March 22, 2021 at 6:12 pm
Alaa Ahmed
SubscriberHello,
I'm trying to simulate oscillating plates installed on a floating platform connected to seabed with mooring lines.
From what I read, I can solve the mooring lines and the motion of the floating platform in AQWA, and then transfer those results to Fluent to include it in the solving process for the oscillating plates.
I can't find anyway to couple AQWA with Fluent, could you please advise me how to do that?
Thank you,
March 23, 2021 at 1:42 pmKarthik R
AdministratorHello,nThere is no built-in capability to couple Fluent and AQWA. Let me check with an AQWA expert to see if your problem can be modeled entirely in AQWA.nKarthiknMarch 25, 2021 at 4:19 pmMarch 26, 2021 at 11:16 amMike Pettit
Ansys EmployeeHello,nWe don't have the functionality to perform 2-way coupling between Fluent and Aqwa at the moment. I think the best you can do is to export the structure motions from the time domain hydrodynamics calculation (plot the motions as graphical results, and use 'Export CSV File...' from the graph details) and then impose these motions in the Fluent calculations.nTo model this in Aqwa you can use Morison Disc elements to model the viscous drag effects on the plates; you may also consider increasing the drag coefficients to account for vortex shedding.nI hope this helps! MikenViewing 3 reply threads- You must be logged in to reply to this topic.
2656
2120
1349
1118
461
