August 24, 2022 at 12:21 am
mkhademi
SubscriberHi everyone,
I want to simulate particles transport in Rocky DEM 2022R2. I read that now it works with a one-way transient simulation for coupling with Ansys Fluent (Only data is tranferred from Fluent to Tocky during the transient simulation of the case in Fluent)
. I could not find any tutorial for this, and I did not see any option directly in Rocky DEM to activate this option. There is a new tab in Ansys Fluent though as in attached picture, but still dont know which option to choose. Any lead?
Thank you so much.
August 24, 2022 at 10:22 am
Nikhil Narale
Ansys EmployeeHello,
As a starting point, I would suggest you to check this webinar on CFD-RockyDEM coupling: Particulate Modeling with RockyDEM | Ansys Webinar
Thank you,
Nikhil -
August 24, 2022 at 1:33 pm
mkhademi
SubscriberHi Nikhil,
Thank you for your reply.
I have seen related webinars and have simulated some of my cases. The previous versions were solving with a tow-way coupling approach or steady fluid flow, but it looks new version of 2022R2 works with a one-way transient flow too. I am not able to set up the model with this new one-way transient case.
August 24, 2022 at 2:02 pm
Ansys EmployeeThe setting is on the Rocky side. Once you have the files from Fluent, link via the CFD Coupling > One way > Fluent-Particle option in Rocky.
August 30, 2022 at 5:51 am
DrAmine
Ansys EmployeeActually once you have your Fluent data (and case file) the work is only to be done in Ansys Rocky as Prof. Rob mentioned.
August 30, 2022 at 6:15 am
mkhademi
SubscriberHi Rob,
Hi DrAmine,
Thank you for your help.
I also found more explanation in the Rocky manual for one-way transient analysis (Section 3.3.11.3 of help manual)
Thank you.
2616
2098
1323
1108
461
