Topics relate to HFSS, Maxwell, SIwave, Icepak, Electronics Enterprise and more
Coupling mechanics and Maxwell 3D
    • Maximilian Wohner
      I want to couple the following behaviour:
      Mechanical generates a mechanical deformation, and at the same time, a body force is calculated in Maxwell 3d based on the Lorentz force (Conductor deformation and, as a result, other the current density). This behaviour should be generated iteratively per time unit.
      I would like to do this in Workbench and it could be a two way coupling.
      The shown figure isn't possible.
      Hope you can help me and thanks a lot for your help.
      Max
    • GLUO
      Maxwell Mechanical 2-way coupling for small deformation is done through a feedback iterator.
      GL
