May 16, 2022 at 8:30 am
hansenli
SubscriberHi,
Is it possible to coupling the heat generation in a sph scribing model using ls-dyna? We would like to see how is the temperature field during the manufacturing process. Is there a keyword that's available to achieve it?
Thanks!
May 20, 2022 at 10:41 pmAndreas Koutras
LS-DYNA supports SPH coupled thermal-mechanical analysis. Some relevant references are available in the dynalook conferences website. Please search for SPH thermal.
Trending discussions- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
3890
2639
1859
1262
606
