CP abbreviation meaning in Solver Output (not coupling equation)
    • Gennaro
      What does CP mean in the following message?
      In the help I found only CP coupling equation, but in this case the meaning is different; maybe is it the computation time (or running time)?
      Thank you in advance.
    • Aniket
      Yes, it CPU time and not the coupling equation CP command.
      -Aniket
    • Gennaro
      Hello @Aniket,
      is there any official document in which I can find the acronyms present in Ansys (e.g. CP)?
      Thank you for your willingness.
      P.S.: do you work for ANSYS?
    • Aniket
      It is not there as far as I know, but check the following link for some other things explaining performance outputs:
      https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v195/ans_per/per_measuring.html
      Yes, Notice ANSYS tag below my DP!
    • Gennaro
      Thank you for all @Aniket. I didn't find the acronym in the help, but the important thing is that now I know its meaning.
      Best regards and good work.
    • anusha
      Hello everyone i have doubt in minimizing compliance , under response constraint i should add constraint has compliance but it is asking compliance limit . can anyone tell me what is the value of compliance limit. And can anyone tell how to find the compliance value in output under solution information. And in objective part I have to minimize compliance but there is option called as program ,force and displacement in formulating part .Can anyone know which I have to select.nnn
Viewing 5 reply threads
