May 15, 2023 at 4:45 am
Plebian Seth Tamba
SubscriberGood day, I want to know how to show the total damage, compression damage, and tension damage in my analysis of RC column. I used the command that Dr. daly0 used in his youtube video https://www.youtube.com/watch?v=IIyuStywNhM&t=1045s
/SHOW,png
/ANG,1,
/VIEW,1,1,1,1 !Use these values to change the view
/gfile,600
SET,last !SET,Last = Outputs final result set
!By DrDalyO
esel,s,ename,215
PLNSOL,MPDP,TOTA
PLNSOL,MPDP,COMP
PLNSOL,MPDP,TENS
PLNSOL,MPDP,RWBut it is not showing anything if the analysis have more than one number of steps. I quite new to using APDL commands. We use the same CPT 215 element for concrete using dracker pager model
Thank you in advance.
May 16, 2023 at 6:12 am
Ashish Khemka
Ansys EmployeeHi,
SET, LAST - this command reads the result for the last set. For multiple load steps try issuing the relevant step number in the SET command and then you might be able to see the relevant results.
How to access the ANSYS Online Help
Ashish Khemka
3311
2469
