Photonics
Photonics
Crash from ‘matlabsave’ command
    • hyunil
      I'm using MODE version 7.17.2647.
      When I execute 'matlabsave', the application always crashes and leaves the following message in the shell.
      What would be the problem?
      a=[1,2,3];
      matlabsave("x");
      HDF5-DIAG: Error detected in HDF5 (1.8.17) thread 0:
       #000: /home/lumerical/temp_hdf/CMake-hdf5-1.8.17/hdf5-1.8.17/src/H5P.c line 299 in H5Pcreate(): not a property list class
        major: Invalid arguments to routine
        minor: Inappropriate type
      attempt to create or open handle failed
      terminate called after throwing an instance of 'H5HandleOpenException'
      /tmp/1626139815.73787302: line 8: 109574 Aborted         (core dumped) /opt/etxcn/bin/ssrrun -fps 500 -sp mode-solutions-app
    • Lito Yap
      Which operating system and version are you running on? Which version of Lumerical MODE and Matlab are you using? Are you running this from the MODE GUI?
      Please see this article for the Matlab integration instructions. Then test the API functions in Matlab after the configuration.
