March 6, 2023 at 2:12 am
info
SubscriberI have noticed with the version 2022r2 and 2023r1 that sometimes when closing a tab or window the program does not respond. Is it some bug that maybe you should know and repair for the next version?
March 6, 2023 at 2:50 am
Devendra Badgujar
Forum ModeratorHello Evangelos Papageorgiou
In most cases, this can be resolved by updating your graphics drivers directly from the manufacturer website (i.e. NVIDIA).
You might also want to clear your user settings from File > SpaceClaim Options > Advanced > Reset All User Settings.
Make sure your computer is using the main graphics card for SpaceClaim/Discovery. Let me know if this works for you.
Regards.
March 8, 2023 at 4:36 am
info
SubscriberDevendra Badgujar I have tried updating graphics but nothing happened.
To reset the user settings is not an option as we need our custom configuration.
So the problem remains, for at least two different computers.
March 8, 2023 at 5:00 am
Devendra Badgujar
Forum ModeratorEvangelos Papageorgiou
Please share the application logs from the location below to ansys-discovery-support@ansys.com
C:Users
AppDataLocalTempDiscovery (Share the entire folder) Also, can you share a short video of the problem to understand this better. Thank you.
- pcb
- No longer possible to import f3d with 2023?
- line bodies and surface body shared topology
- How to chang unit in Ansys Discovery 2023?
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- SpaceClaim Script: Selection by FilterByBoundingBox
- Assignment of revolute joint
- Max/min over time results in AIM
- Axisymmetric model – Rubber seal
- To change language in Ansys Discovery
8808
4658
3153
1680
1470
