March 13, 2021 at 6:00 pm
ludo
SubscriberHi,
I imported a .step format geometry and I could not create a body from the surfaces. The fill function in SpaceClaim does nothing, same with DesignModeler..
Do you have any idea ?
Here is my geometry :
March 15, 2021 at 6:32 amKeyur Kanade
Ansys EmployeePlease see Repair - Stich and Repair - Gaps. nAlso check missing faces. nPlease try to use only half and later you can mirror it. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student CommunitynMarch 16, 2021 at 10:24 amludo
SubscriberThanks a lot, it worksnViewing 2 reply threads- You must be logged in to reply to this topic.
Trending discussions- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2656
2120
1347
1118
461
