Create a checkbox in an Ansys ACT wizard performing post-processing automation using CFD-Post
    • Ali_Maktabifard
      Dear colleagues,I want to add a check box for a property in my Ansys ACT wizard to get a True/False signal from the user for whether enabling or not enabling a For loop in my Python code performing post-processing automation using CFD-Post. How could I create this in my XML file and connect it to my Python code?nThank you in advance for sharing your priceless experiences with me.n
    • Aniket
      I am assuming you have all the code for wizard ready and need enhancement to your wizard/extension.nOpen the app builder and import your wizard add the checkbox using UI and export once you are done.nPlease check the link (https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v201/en/act_dev/ch04s05s06.html) for more info.n-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning Forumn
    • Ali_Maktabifard
      It is not possible to do that for CFD-Post inside ACT! I wanted to know the XML command for a radio button.n
