September 27, 2017 at 11:19 am
nselvara
Ansys EmployeeHow do I create a helical revolve in SpaceClaim Engineer?
October 17, 2017 at 7:02 am
cbhavsar
Ansys EmployeeTo create a helical revolve §Select the Pull tool. §Select the face or edge you want to revolve. §Alt+select a line or an axis to revolve about. §Click the Revolve helix option in the Options panel and enter dimensions for the helix.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2656
2116
1339
1118
461
