Create a new zone and monitor it in report plot
    • ecrod
      Hello All,
      I am simulating a multiphase flow inside an annulus in Fluent. See figure attached (red arrows represents flow direction).
      I am able to monitor the volume fraction as function of time inside the whole annular volume. However I would like to monitor it only in the expanded region.
      I know it can be done in the Adapt tab and mark cells for a new zone. But, this zone I am creating is totally different from cylinder shape in the expanded region.
      What would be the best way to create this volume ?
      How it can be done in CFD-Post ?
      Thanks in Advance.
    • DrAmine
      Ansys staff do not look into attachment. You can insert your picture. From the description and if you can identify the "zone" by coordinates you might create a Expression Based Report Definition.
    • ecrod
      Hi abenhadj,
      Follow my figure below.
    • Karthik R
      Administrator
      This is how you should be able to create an Expression based monitor. But, if I remember right, this might not be possible in 19.2. Could you please check if you are seeing this option?
      Thanks.
      Karthik
    • ecrod
      Kremella,
      I am able to see it. But my tab is different from yours.
      However, in the left column, from Named Expressions I have it.
      Thanks.
    • Karthik R
      Administrator
      This might be because of different versions. But, this is what my colleague Amine is referring to.
      Thanks.
      Karthik
Viewing 5 reply threads
