3D Design
3D Design
Topics related to Ansys Discovery and Ansys SpaceClaim.
Create a Report
    • Walter Otiniano
      I used to create a report  (html format) but for some reason I can't now when I am in the structural physics. Any idea what's going on? thank you. Assuming this is fixed, is there any other friendlier document that the report can be edited. Thank you., too.
      Walter
    • Atharv Joshi
      Forum Moderator
      Hi Walter Otiniano
      Can you please elaborate what is the issue and if possible, share a screenshot of the error?  Does this issue happen only while creating report for Structural physics or for Fluids and Thermal as well?
      Please, make sure you have an updated Flash player to view the html file.
      Please note that you can also save the report in .doc format. Can you please try that as well and let me know?
      Thanks & Regards
    • Walter Otiniano
      This happens only when I am in Structural analysis.
    • Atharv Joshi
      Forum Moderator
      Hi Walter Otiniano ,
      Can you try creating reports for sample structural simulation and check if it works to know if the problem is model specific.
      I will need application logs which can be found at the below default location. Please share the latest folder after trying to create report, to discuss the issue with development team.
      C:UsersAppDataLocalTempDiscovery
      Thanks and Regards
Viewing 3 reply threads
