Discovery Import
Discovery Import
Create a sketch dimension between two lines in script
    • Guillaume ANFOSSI
      I have to create a sketch dimension with script between two differents parallel curves (lines).
      I try to use "Dimension.CreateDistance" but i get this error : Input selection is not a valid one.
      Could you pease help me ?
      Thanks.
    • Naresh Patre
      Hello GUICAD
      I used the record functionality and was able to record the operations for creating a dimension between 2 parallel lines. See below snapshot:
    • Guillaume ANFOSSI
      Hello Naresh,
      Ok, it works with parametric sketch.
      Thanks,
