March 15, 2021 at 11:23 am
atulsingh92
SubscriberHello all,
In Design modeller, I have the following
here, the green should be a wall condition while the two rectangles in yellow should be an outlet condition ( or Named selection).
When I select the 2 yellow and define them as outlets, than it is allright, but then I want to select the green surface minus the two yellow rectangles and then define them as wall.
How can I do that?
March 15, 2021 at 11:40 amKeyur Kanade
Ansys EmployeeYou need to split the surface. Please check under Tools - Split FacenPlease go through help manual for more details nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student CommunitynViewing 1 reply thread- You must be logged in to reply to this topic.
Trending discussions- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2588
2080
1315
1108
459
