March 19, 2022 at 6:35 am
seghier
SubscriberHi;
How to create a command
SpaceClaim.Api.V21.Command.Create()
from this?
Group.SetDimensionValue
active = SpaceClaim.Api.V21.Window.ActiveWindow
groups = active.ActiveWindow.Groups[0].SetDimensionValue(10)
March 22, 2022 at 5:21 amAniket
Forum ModeratorSorry your question is not clear, can you please rephrase it?
-Aniket
March 26, 2022 at 1:57 pmseghier
SubscriberThanks Aniket, i find a solution
I just want know how to create command and use it but i found this must be done in the Addin
Viewing 2 reply threads- The topic ‘Create command how?’ is closed to new replies.
Trending discussions- pcb
- No longer possible to import f3d with 2023?
- line bodies and surface body shared topology
- How to chang unit in Ansys Discovery 2023?
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- SpaceClaim Script: Selection by FilterByBoundingBox
- Assignment of revolute joint
- Max/min over time results in AIM
- Axisymmetric model – Rubber seal
- To change language in Ansys Discovery
8808
4658
3155
1688
1480
