Discovery Import
Discovery Import
Create menu moved to Sketch tab
    • mh
      How do I get the sketch panel back to the Design tab? - You made the daily work much harder and more cumbersome - please move it back.
      Regards, Users against the sketch tab
    • Charudatta Bandgar
      Hello Michael Holm ,
      Sorry for the inconvenience caused.
      If you go to SpaceClaim Options>Advanced, if you disable "enable constraint-based sketching) the Sketch tab disappears and the sketching tools come back to the Design tab (as before). For this, after you do the changes, restart is required.
      Please refer to the image below.
      Regards.
    • mh
      Thank you.
      Where can I learn about constraint-based sketching ?
        Here in these tutorials, the first two videos explain the constraint-based sketching. Along with these videos, the SC 2020R2 documentation has terminology explanation.
        Regards.
