Create new parameters with report definition
    • ChicoElizio
      Hello everyone. I am doing the simulation of an aeronautical combustion chamber using Fluent and I need to calculate a parameter as a function of the temperature entering the chamber (known) and the average and maximum temperatures at the exit of the chamber. During the simulation, the solver already calculates the report definition for the two outlet temperatures. What I can't do is create a new parameter to calculate (T_max_out - T_av_out) / (T_av_out - T3).
      Another doubt. The simulation is carried out initially without chemical reaction, only air is used until its convergence. After that the simulation is done with a chemical reaction, then the radiation is added and finally the NOx calculation. How can I automate this sequence?
      I use ANYS 19.2. Thank you very much for your attention.
    • DrAmine
      you create an Expression Report Type. To automate use journal file and/or Automatic case Modification
    • ChicoElizio
      Thank you so much for your help. I'll do it right now.
      ChicoElizio
    • ChicoElizio
      Dear abenhadj.
      I'm using Automatic case Modification and it's running perfectly.
      Thank you again.
      ChicoElizio
Viewing 3 reply threads
