create nonlinear BC in Fluent dynamic
    • Hoosein86
      could you please help me that how can I  define a nonlinear BC in (Blade) CFD Model.
      Thanks
    • DrAmine
      More details please.
    • Hoosein86
      Clould you please tell me wich Infos  or details you want to know?
      Best Regards
      Hossein
    • DrAmine
      Details about application, solver what you want to do?
    • Hoosein86
      The Model is in Fluent, and at my project I have to define a nonlinear BC in (Blade) CFD Model.
      My quastion is How can I do this?
    • DrAmine
      What do you mean with non linear boundary condition? What do you mean with (blade)?
    • Hoosein86
      this is the Topic of my Project : "Unsteady (Instationäre) flow simulation on a compressor stator grid using variable boundary conditions(Instationäre)" and I have to define a nonlinear BC.I have to finde a way to create a Non Linear BC.Hope you can help me.
      Best Regards
      Hossein
    • DrAmine
      Yes: what is non-linear in your BCs?
    • Hoosein86
      I have to write an equation(Parameter)in inlet part that is related with time
    • DrAmine
      Okay and what is now the issue with that equation? What are the dependent variables? Do you want to use UDF for that?
    • Hoosein86
      I want to write an Equation that cause a Non-Linear BC.how?!
      the dependent variable could be the Z Coordinate.
      I an not sure how could be this Equation.
      Best regards
      Hossein
    • DrAmine
      You can use an Expression for that. You require a bit more actual release. Another universal approach is to write DEFINE_PROFILE UDF. There are some example in the manual showing that.
    • Hoosein86
      what do you mean to use Expression and actual release?
      BR
      Hossein
    • DrAmine
      Using one of the latest versions of Fluent. Here you can use Expression not custom field function for profile description.
    • Hoosein86
      Thanks for your answer.
      I want to write an Equation to Velocity that is not Constant, do you know what should I wtite to have No Unit to be able to calculate the Sinus Funktion ?
      Best Regards
      Hossein
    • DrAmine
      Do not use that. You require UDF or Fluent Expression Custom field function are wrong here.
    • Hoosein86
      First I have to write from custom field function.
      If it is not wort I will try UDF
    • DrAmine
      It would not work from that only if you initialize and the custom field function in a profile and use that later as boundary profile
    • Hoosein86
      Then How should I write UDF?
      using the custom ield function is much simple way to define the non steady flow.
      I have to write two Equations that change magnitude and Direction.
    • DrAmine
      Yes or update to new version and use Expression. I hope you got it now.
Viewing 19 reply threads
