TAGGED: designmodeler, mechanical-apdl, model, pattern, preprocessing
June 1, 2022 at 9:19 am
tim.hertinger
SubscriberHi guys,
I´ve got a question regarding my current model in PyANSYS:
I want to model a tapared roller bearing including rollers, inner ring and outer ring. I have modeled both rings and one roller.
Now I want to copy that one roller by creating a pattern of a defined angle. Therefore, I want to create the other 15 rollers by a pattern, without modelling each individual roller.
I know there is the VGEN command that creates additional volumes from a pattern of volumes.
But how can I implement an angle instead of x- and y-coordinates.
Thank you for your help!
Best regards,
herttim
July 6, 2022 at 3:11 pm
Aniket
Ansys Employeewouldn't that be based on the conversion of polar coordinate system to the cartesian coordinate system?
- check element type
- Meshing Error
- How to resolve Mesh Failure
- Error in meshing
3862
2639
1859
1254
600
