Created 1-Way FSI Setup in Windows to Run in Linux
    • Tolga
      Hello everyone,
      Currently I'm working on a project which investigates flow effects on composite wing. To do so, I created the wing as composite material and solved CFD to transfer as 1-Way to structural. Since the rest of the project will take long time, I need to use a HPC and that HPC has Linux OS. How can I transfer my files (files created in Windows) into Linux OS while having CFD Results and ACP data? Creating input file for apdl from Structural would be enough or not?
      All the best,
      Tolga.
      If you archive the project and move the archive it ought to sort all the paths out when you extract it at the other end. Just remember to include all of the results etc.
    • Tolga
      Thanks for your reply.
      All the best.
