September 2, 2019 at 5:47 pm
chukster97
Subscriberhello im very new to ansys mechanical apdl, im trying to create a simple model for my project "VM5 is the code for ansys model", a beam with a load on the end. can someone create a simple model with log file to show me how it works.
September 2, 2019 at 6:16 pm
SubscriberPlease reply with a complete problem specification.
For example what is the beam
- length
- cross-section
- material
- load
Do you have to use APDL or can you use Workbench?
September 2, 2019 at 8:50 pm
chukster97
Subscriberthe length can be 30mm with a 5mm cross section, the material can be shell181 with a load of 10N. i wish to use ADPL because its the software i learnt to use in university, thank you.
September 2, 2019 at 9:26 pm
SubscriberWhat is the shape of the cross-section? A circle, a square. You have only given a dimension.
shell 181 is not a material. A material is steel and has an Elastic Modulus. What is the Elastic Modulus?
I can only help you with Workbench.
September 2, 2019 at 10:46 pm
chukster97
Subscriberthe young modulus is 200gpa, is it possible to port workbench models to adpl?
September 3, 2019 at 2:57 am
SubscriberYes, but if you start in Workbench, you can complete the project in Workbench.
September 3, 2019 at 5:04 pm
chukster97
this is the link to the model im trying to create just the basic drawing, theres two of them with a cylinder as a second and a load of 10N.
September 3, 2019 at 8:10 pm
September 3, 2019 at 8:19 pm
SubscriberDo you have the theoretical solution to a 10 N load on the 10 mm square cross-section 50 mm long beam?
Get started by creating that beam solid in SpaceClaim.
September 3, 2019 at 9:32 pm
chukster97
Subscriberi have no theoretical solutions, i just need help to make this. is it possible to model it then send a download link so i can run the simulation calculations i need? thanks
September 4, 2019 at 12:31 am
SubscriberHere is the equation to calculate the tip displacement with an end load for a uniform section cantilever beam provided by a lecture at MIT.
Do you know how to calculate I for the square cross-section? Wikipedia has that equation.
In your case, h = b and Ix = Iy.
Please reply with the tip displacement you calculated using those equations for your inputs.
Next start a beam model in ANSYS to see if you get the same answer.
You will need to open SpaceClaim. Draw a line 50 mm long, and create a beam with a square profile with a 10 mm side length.
September 4, 2019 at 9:13 am
chukster97
Subscriberi told you i have no idea how to use it, doesnt matter i'll ask someone else.
September 4, 2019 at 3:59 pm
SubscriberI'm here to help you learn how to use ANSYS. I assume you have installed the software.
- Step 1. Open Workbench.
- Step 2. Double click on the Static Structural analysis system in the Toolbox.
- Step 3. Double click on the Geometry cell in the Static Structural system.
- Step 4. Draw a line 50 mm long in SpaceClaim.
If you can accomplish these few steps, we can cover the next few steps.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2518
2064
1279
1094
456
