Creating a custom enclosure
    • MuaminBasil
      Hello All.
      I have hit a bit of a snag in my learning experience with Fluent. I am trying to test different air inlet setups on a fin, as per the photo attached, and I am unsure of how to achieve an enclosure with the inlet being part of the enclosure. I am trying to design an 80mm circular inlet that is raised 20mm off the top of the enclosure wall as in the photo but I am unsure of how to go about it? I understand the basics of enclosure use, where you draw up the cushions, and and define the named selections that you call again within the fluent setup, But I am unsure of how to go about doing it this way. I want to then move the inlet to the side walls, and even test an outlet for example but I am unsure of how to go about it. Is there a way to create a custom geometry for the enclosure and treat is as an enclosure?
      I'd appreciate any help in this regard.
    • Keyur Kanade
      As ANSYS Staff, we can not download attachments. Please upload images using upload image functionality.
      You can create custom geometry and use it as enclosure in SpaceClaim.
      Regards Keyur
