March 18, 2021 at 12:50 pm
atulsingh92
SubscriberHello,
There is one common channel feeding fluid to channel top and the bottom. I want to obtain pressure at the two channels separately.
I tried creating a point and normal plane, but that becomes only one plane which has the desired surface, but gives a total pressure at both the top and bottom red zones shown below and not separately.
How can I either create a separate plane at both the top and bottm channels to calculate pressure separately?
March 18, 2021 at 2:33 pmRob
Ansys EmployeeLook at the iso-clip surface tool. nMarch 19, 2021 at 9:02 amatulsingh92
SubscriberSo, iso-clip surface shortens or elongates the plane-5 on which the pressure is to be calculated. So I would have some from the botom plane and some from the top plane, and never the top plane only.nnAlso, the plane, is still across both the channels of top and bottom, as it was created with point and normal. So would probably need some suggestion to just bound that plane upto only the top channel, if that were possible ?, in order to retrieve the pressure at only the top channel?n
March 19, 2021 at 3:19 pmRob
Ansys EmployeeMaybe try clipping by location? Click on the arrow to the right of Pressure in the above panel. nViewing 3 reply threads- You must be logged in to reply to this topic.
2656
2120
1345
1118
461
