Creating a line in fluent
    • rumth
      I have created a line (using new surface from contour option) before solving. After creating the line, is there any option to see the line points? I have generated 10 lines to measure the velocity. If I want to check the decay velocity at different points along the centerline of the inlet, how can I see that?
      suppose gas jet velocity impact on a liquid pool and a cavity is formed. How can I measure the diameter and depth of the  cavity in CFD result? Also how can I measure the droplet size in CFD result?
      Thanks,
      Raju.
    • Keyur Kanade
      Please select 'rake' instead of line. Then display this 'rake'.
    • rumth
      Is it possible to show the coordinates of the rake after creating once?
    • Keyur Kanade
      I dont think its possible.
      go to viewing tab and select mouse - probe - long description.
      now use right click on say contours. it will give coordinates and other info.
Viewing 3 reply threads
