February 28, 2022 at 10:48 am
Lylad
SubscriberHi I am creating a simulation with a cow releasing infectious aerosol, I can created my flow and while running my particle results I have been using the colour by discrete phase variables and DPM concentration. But I am just a bit confused about the units it says the units are kg/m^3, so I am just a bit confused what this meaning in terms of concentration and how it can be interpreted.
Also when trying to change the units I noticed the default for DPM concentration says 1.e15-particles/ kg, I am also confused what this means?
Thank you :)
February 28, 2022 at 4:37 pmRob
Ansys EmployeeThere aren't alternative units for DPM Concentration, but there are for concentration. I think the particle-conc is something else, especially as it's per kg, lb or g but the 1e15 remains constant.
March 2, 2022 at 3:02 pmLylad
SubscriberHi rob thank you so much for your reply, I just wanted to ask another question, when your creating the injections one of the options for point properties is the Flow rate (kg/s) for the particles, the default value is 1e-20, but is this something you need to calculate beforehand ?
If so is there a formula to calculate the flow rate ?
March 2, 2022 at 4:01 pmRob
Ansys EmployeeYou need to give the solver a flow rate if using two way coupling. The 1e-20 kg/s is for one way as the solver needs a mass for something. Historically if we were just tracking particles one way (flow affects the trajectory but trajectory doesn't alter the flow) we set a mass of 0 kg/s.
Flow rate is how much mass you want in the system. We use a parcel method so you're tracking the parcel not the particle: not helped that everyone always muddles the two terms.
March 2, 2022 at 4:20 pmLylad
SubscriberHi rob thank you for your reply, I am using a one- way simulation so that fine but would it be best to leave the flow rate at 1e-20 or change it to 0 as you said.
March 2, 2022 at 4:22 pmRob
Ansys EmployeeDon't change to zero. You won't get any particles if you do that! So leave the mass flow as 1e-20.
March 2, 2022 at 4:23 pmLylad
SubscriberThank you so much :)
March 2, 2022 at 4:23 pmRob
Ansys EmployeeYou're welcome.
Viewing 7 reply threads- You must be logged in to reply to this topic.
2688
2134
1349
1136
462
