Preprocessing
Preprocessing
Creating a specific mesh
    • jonas66
      I am relatively new to Ansys and want to create a mesh which creates nodes in the corner of each surface. And i want to remove the meshing lines(shown below) which go across each surface.
    • peteroznewman
      You could try having surface geometry instead of solid geometry.
      When you mesh the surface, you will get mostly quad shell elements.
    • jonas66
      thank you very much ! your advice helped with most surfaces.
      The only surfaces that couldnt be meshed properly were the following two seen below:
      Is there a way to get rid of the nodes ?
    • peteroznewman
      You can have triangles around the top with a node at the center.
      Another approach to meshing a circular face like the one on the bottom is the O-grid pattern. You need to split the face to get this to happen.
Viewing 3 reply threads
