Creating a XY plot for total pressure with x axis as the center line of a surface
    • Dilini
      I want a plot of total pressure along the center-line of a selected surface. For that when I try the XY plot in Fluent results, I can only choose a surface as my x axis but not a line. How can I get this done?
      (For this I am not using CFD post since the pressure values the CFD post gives are static values as I know. If it is possible to get what I want from CFD post let me know. I want the total pressures)
    • Keyur Kanade
      you should be able to select a line.
      how are you creating a line? use results - create - line.
      for range, you can use axes option.
      in cfdpost you can add static and dynamic pressure and create a new variable to plot.
      Keyur
